Parts failure poll: P2 Volvos: V70/S60/XC70 from 2001-2007
This topic is in the MVS Volvo Repair Database » Failed Parts Poll for P2 Volvos
What has failed on your P2 Volvo: V70/S60/XC70 from 2001-2007?
abs module
62
1%
ac compressor
62
1%
alarm system
126
3%
alternator
86
2%
axle shafts
95
2%
blower motor
66
2%
brake cylinder position sensor
18
0%
brake master cylinder
22
1%
broken ignition lock
26
1%
cabin switches
30
1%
catalytic converter
30
1%
cem (central electronic module)
33
1%
center console cover
65
2%
center console cup holder
62
1%
climate control fan
29
1%
climate system (including software upgrades)
26
1%
control arm bushings
177
4%
delaminated shoe on the parking brake mechanism
54
1%
discolored roof trim strips
113
3%
door whether strip
56
1%
engine cooling fan
29
1%
etm (electronic throttle module)
85
2%
exhaust flex down pipe
20
0%
exhaust pipe hanger broken (rusted, etc)
91
2%
front strut mounts
161
4%
front struts
146
3%
front window mechanism, slider or switch
76
2%
fuel pump
66
2%
fuel door hinge
123
3%
fuel door latch (not hinge)
84
2%
fuel tank pressure sensor
16
0%
headlamp ballasts (volvo calls them "Control units")
13
0%
headlamp leaky seal
38
1%
ignition coils
115
3%
ignition key failure (key replacement, programming)
13
0%
immobilizer antenna (start prevented error)
15
0%
lower ball joints
104
2%
lower torque rod
48
1%
oil sump seals
20
0%
other cup holder
28
1%
oxygen sensors
66
2%
parking brake cable
26
1%
passenger airbag sensor
6
0%
pcv system
123
3%
premature lightbulb/bulb socket failures
119
3%
radiator leak
79
2%
radio display
34
1%
rear view mirror
59
1%
rear bearing housing ("Knuckle")
6
0%
rear latch mechanism
27
1%
rear main seal
19
0%
seat controls cover
15
0%
seat motor
5
0%
siren control module
86
2%
spring clip to hold head light bulb
9
0%
spring seats
48
1%
steering rack
31
1%
steering wheel
4
0%
steering wheel controls
3
0%
sway bar links
135
3%
the turbocharger (whole thing)
17
0%
tie rods
128
3%
transmission (including software upgrades)
100
2%
transmission mount
93
2%
turbo valve
21
0%
turn signals
45
1%
upper engine mount
215
5%
vacuum pump/vacuum switch
18
0%
vvt solenoid
37
1%
water pump
29
1%
wheel bearings
98
2%
yaw sensor (anti-skid service required)
18
0%
Total votes: 4248
pa cockle
Year and Model: 2002 v70 xc
Post by pa cockle »
Hi , could someone please tell me the official VOLVO reason for the .o. rings on the dip stick and the ramifications of not having them there..
this sounds a silly question but I am going somewhere with this,..it's doing my head in.. cheers Pa..
Denton
Year and Model: 1996 854R
Post by Denton »
carboncow wrote:I got 22 of them (OK on two cars) but I still want to know what I win?
21 on my one V70 T5 with 196k but that's since new using P/O records. My transmission vote isn't fair since it was a software reflash in 2005.
IceCold4x4
Year and Model: 2006 Volvo S60R GT
Post by IceCold4x4 »
i saw no option for angle gear failure on the AWD models.
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
I thought I would update my count to 32 items now between two cars. This is only a year later after the original post. I would have to say I w/o Vida Dice in my life I would not even remotely still own these cars!
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
sleekitwan
Year and Model: V70 D5 2003
Post by sleekitwan »
Good idea, looking for the area to submit my own now...oughtta get Volvo to look it up? Maybe they do already.
sleekitwan
Here's my contribution, I summarised the info from the poll of failure issues, and came up with this - forgive parochial stuff that pertains to spelling etc, I am from the UK:
V70 MkII TOP 5 FAILURES
In order:
1 UPPER ENGINE MOUNT - 42 votes, 5%
2 CONTROL ARM BUSHINGS - 39 votes, 5%
3 FRONT STRUT MOUNTS - 33 votes, 4%
4 SWAY BAR LINKS - 29 votes, 4%
5 TIE RODS - 27 votes, 3%
5a PREMATURE LIGHT BULB - 27 votes, 3%
6 ALARM SYSTEM - 25 votes, 3%
- also SIREN CONTROL MODULE fault gets 17 votes and 2%, likely related, the module fault under right front wheel arch causes this.
7 FRONT STRUTS - 24 votes, 3%.
8 ETM (ELECTRONIC THROTTLE MODULE) - 21 votes, 3%
9 TRANSMISSION MOUNT - 20 votes, 2%
9a TRANSMISSION INCLUDING SOFT UPGRADES - 20 votes, 2%
9b IGNITION COILS (on petrol cars only) - 20 votes, 2%
10 AXLE SHAFTS (not drive shafts/CV joints?) - 19 votes, 2%
10a EXHAUST PIPE HANGER BROKEN/RUSTED - 19 votes, 2%
(NB this may be more likely on petrol models due to internal issues?)
NB A common fault after a few years is the AirCon needs re-charging, this is so common it must be in the top 10, but is not mentioned specifically in the list.
So, if you wanted to know where to start, this list would be it. VALID AS OF 29th APRIL 2013.
Best to all.
WhiskeyTangoFoxtrot
Year and Model: 2001 V70 T5a
Post by WhiskeyTangoFoxtrot »
My major repairs so far on an '01 V70T5a
113k (New to me) - Oil pump and all related seals replaced. Troubleshoot SRS error to no avail.
130k - Replace front suspension components, struts, spring seats, top strut bearings
145k - Replaced front brake pads and rotors.
147k - Almost failed smog, will probably need to replace O2 sensors and catalytic converter before next smog check.
I know that the top engine mount is going bad, as well as the forward engine torque mount. Front subframe mounts could use replacement. Rear wiper arm is broken. Sunroof works only as a vent, will not roll back without grinding on something.
"Oil pump" should probably be added to the poll...
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I don,t see flexible brake lines at the front wheels. Mine were both cracked and needed replacement.
none77
Year and Model: 2004 XC70
Post by none77 »
Front Coil Spring recent broke, and I think Window regulator needs replacing.
westdouglas
Year and Model: v70 2.4t 2001
Post by westdouglas »
transmission, turbo control valve,front pass side axle,both wheel bearings,intake cam oil seal,maf,engine torque mount,all front suspension,gas door lock/latch,inside door panel,console hatch.
