1999 Volvo S80 T6
rharding91
Year and Model: 1996 850, 1999 S80T6
1999 Volvo S80 T6
Post by rharding91 »
Need some help, bought this car and it turned out to be a dump. I am a DIY kind of guy though so I am hoping with some help I can get roadworthy again.
The problem I have is I was doing a compression test on my cylinders and the starter stopped engaging. So I took the starter out along with a whole bunch of other stuff to get to it. Now I dont know where this wire goes! I put it on the body of the starter and it started smoking. Here is some pictures.
Eldoninoz
Year and Model: S80 1999
Post by Eldoninoz »
That wire is a hot wire, it would go to the starter to an insulated terminal. From the pictures you provided it looks like you have it connected to ground. You would be pumping a lot of amperage to get it hot enough to smoke. It would most likely attach to the solenoid close to the block attached to the starter motor.
yuckuJackD
Year and Model: XC70; S80; S40
Post by yuckuJackD »
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
