Bad kharma to say the least it had BOTH a blown head gasket and a cracked block.
I didn't order the stuff to redo the head until I had the head off to make sure it was the the gasket.
It was very obvious the head gasket blew out between the cylinder wall and the water jacket right by the timing belt area. I wish I would have taken a picture to show you how bad it was.
oil mixed with water and on ground after head gasket repair
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
That's incredible (in a bad way). You definitely used up all your bad luck and a whole bunch of mine (thanks BTW). I didn't even know these cars could crack like that. What would do that? Is a HG failure that catastrophic? That would take a ton of energy to blow out the side of the motor like that.
1995 850 GLT Wagon w/ 200,000 miles
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
A really, really bad overheat.
'98 S70 T5
2016 Chevy Cruze Premier
jpr0204
- Year and Model: 12' XC70 Prem. Plus
The ONLY time I've EVER seen a block crack like this is when it is below freezing out and the owner starts the car with no coolant in the system...
Obviously not stating that is the case here, just saying this is the only time I've ever seen this type of situation before.
- Joe
- Joe
Current Vehicles:
20' Kia Sorento (Lease) (Fiancé's car) Currently at 19,500 miles
12' Volvo XC70 Premier Plus AWD Currently at 95K miles
12' Yamaha V-Star 950 EFI Tourer (My daily summer crusier) Currently at 5K miles
04' Yamaha V-Star 650 Classic (Fiancé's daily summer cruiser) Currently at 16K miles.
- Been thanked: 4071 times
I thought the same Joe, but OP was in TX?
If I remember correctly (like I said it happened about 3 years ago) I made a trip to North Dakota in the winter and it was REALLY cold. It was shortly before the problems started occurring ... I drove it all the way back to South Texas though.
Also, when I lost the coolant (here in South Texas) it was pretty much instantly because the radiator failed where the upper hose goes into it, and it completely detached. I was cruising along nicely at about 70 mph and suddenly had steam everywhere. The car quit, I coasted to the side of the road and and lifted the hood. The engine compartment was drenched with oil and water, and steam was coming off of everything.
1998 V70XC
Im beginning to think small crack in ND, propagating and then catastrophic failure in TX..
Bummer
Bummer
- 5081 Views
Last post by kallekula
- 778 Views
Last post by RickHaleParker
- 11 Replies
- 2609 Views
- 18 Replies
- 6147 Views
- 514 Views
Last post by erikv11
