1999 V70 T5 DIY Front Caliper 8111102 8111101 DIY in 50 minutes!!
Has thanked: 379 times
Been thanked: 1186 times
OK - good mechanicing is not a race, but I had an hour of time in a boring conference call where I was just a listener, so I plugged earphones in and dashed outside.
My front left caliper locked up on me so I got two rebuilt ATE calipers from BAP GEON (in stock, local, 42 USD with 16 USD core) - you need to specify both wheel size and rotor size - mine were 280mm, 305 mm is the other option.
Safety first<br />Nitrile keeps brake fluid off hands<br />Heavy gloves for wrestling tire, caliper in front sups<br />Impact glasses keep brake springs out of eyes<br />Real jackstands please
Safety first
Tools used <br />15mm Caliper bolts<br />7mm hex - caliper slide pins<br />10mm, 11mm - bleed screws
Tools used
15mm Caliper bolts
Ready??
Ready??
Slacken (just crack) brake hose with 14mm open end. You will spin the caliper off by hand later once it is off the rotor
Caliper off - rest it on control arm - do not hang by brake hose!
Once caliper pins (7mm hex) are loose, I pry out caliper with flat pry bar and gentle hammer taps
Load inboard pad into piston, use screwdriver to push springs in to slip into piston recess - sorry, hard to photo with two hands
Top view of caliper in carrier - green is hose connection, silver new bleed screw, and shiny new greased caliper pins!
New bleed screw was 10mm, old one 11mm
Caliper loaded and ready to go on - careful observer will note Ive forgotten to remove caliper mount as I didnt realise new caliper came with new one!
Start the Caliper mounting bolts carefully, by hand, use blue (medium strength) locking compound, and get them nice and firm
Double check that caliper pins are tight - 7mm hex
Start brake hose carefully by hand, spin caliper to hand tight, then about 3/4 turn on flare thread with 14 mm open end
Load spring into position...
Reinstall spring - thumb pressure where index finger is, pliers pull loop down to push up on pad
Bleeder on caliper was 10mm, original 11 mm - note loop in hose to keep bleeder wet - I ran about 250 mL of brake fluid through new caliper and found brakes were great after this. Pressure bleeding system after having it open is highly recommended.
All ready to Roll!!! 52 minutes !!
Link To Volvo Glossary
Year and Model: Many Volvos
Been thanked: 56 times
Re: 1999 V70 T5 DIY Front Caliper replace in 50 minutes
Post by Ozark Lee »
Well done!
You are lucky that the brake line came loose with what appears to be minimal pain. The lines are notorious for seizing in place.
Thanks Lee!
It's pretty easy to move it (14mm) while the caliper is firmly attached to the wheel - I've found once you remove it that job gets nasty.
I did leave out the pin removal picture, will edit
Re: 1999 V70 T5 DIY Front Caliper 8111102 8111101 DIY in 50 minutes!!
added part numbers to thread title to search
Rattnalle
Has thanked: 20 times
Been thanked: 124 times
Post by Rattnalle »
I did one of mine on my 04 the other week though its exactly the same. Almost exactly one hour from when I had my tools ready and started taking the wheels off. I got away with gravity bleeding it though, it just started pouring through after I took the lid off the reservoir so I just kept filling until a deciliter or two had run through :-)
wizechatmgr
Has thanked: 24 times
Been thanked: 63 times
Post by wizechatmgr »
Now if only Abscate would buy a brake lathe =)
1999 V70 XC AWD - ~193k miles
I think Gochees has one in Delmar. It's a rare sight seeing someone carrying discs through a money and brains neighborhood on the way to the auto shop
ZionXIX
Has thanked: 9 times
Been thanked: 46 times
Post by ZionXIX »
lol, I did this over new years with a junkyard caliper. Once everything is cracked loose it goes very quickly. Something I will never understand is european calipers using allen head type bolts. My tool kit has 2 sided allen extension bits. The problem is that they are nearly 8 inches long which makes the (3/8" socket + adapter + the allen bit) a very tight fit. I definitely to invest in a couple of standalone allen sockets.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 653 times
Been thanked: 278 times
Post by matthew1 »
Why isn't this in the Repair Database? Who's in charge around here? :roll: :wink: Management, I'd like a complaint form please. I've got some writing to do.
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
There’s a slight subtle point here I should have explained better.
The caliper hose is attached hard to the caliper and then to the flexible hose attached to a bracket. The hose/hard line connection is the tough one to break, so what I do is crack the line at the caliperwhile mounted, unmount the caliper, then unscrew the hose by turning the caliper. If the hose is in good condition this saves a lot of hard work.
