2000 s80 t6 dead
dshoover2
Year and Model: 2000 s80 t6
2000 s80 t6 dead
Post by dshoover2 »
hi I bought this car a month ago drove it home. battery was dead jumped it all ok battery went dead again charged battery now no dash lights. car will not crank . checked all fuses o.k. radio is the only power option that works. lights inside door stays on till battery goes dead I have a snap on modis and get no communication with car
rerobin66
Year and Model: 2000 S80 T6
Post by rerobin66 »
Two days after I bought my 2000 S80 T6 I had to buy a new battery...no troubles with battery since and that was in January
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
To start modules in these newer cars properly you need to have ignition in PosII THEN connect battery.
Azdude
Post by Azdude »
dshoover2 wrote:hi I bought this car a month ago drove it home. battery was dead jumped it all ok battery went dead again charged battery now no dash lights. car will not crank . checked all fuses o.k. radio is the only power option that works. lights inside door stays on till battery goes dead I have a snap on modis and get no communication with car
Dshoover2, have you done the key lock trick? That where you put the key in the drivers door, lock and the unlock 3 times. That resets the "security system" Also check in engine compartment fuse / relay box, there are 3 or 4 torx head screws that hold the actual panel in, take those out and look under it, that's where Volvo hid all the main system fuses. Also could be a bad ignition switch, the electrical part that is, if you drop the lower plastic cover from the steering column, its on the side closest to the door, unplug it and see if all your lights go off..
dshoover2
Post by dshoover2 »
hi i looked in the fuse panel under the hood found no torx screws found 2 8 mm nuts looked under the fuses found no other fuses tried door trick no luck also unplugged ignition no luck bought two computers also no luck
The other poster is referring to the old P80 fuse panel location. What computers did you try?
dshoover2
Post by dshoover2 »
there are two under a cover under the hood tried them both
You can't swap engine and transmission computers on a P2 series car. The original computers are mated to the car's VIN
dshoover2
Post by dshoover2 »
i know but i thought that maybe i would at least get dash lights or something to let me know im on the right track
More than likely a faulty CEM module.
