Blower motor screeches - 86 740 Turbo Wagon
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
zaphod
Year and Model: 1986 740 Turbo Wagon
Post by zaphod »
The blower motor screeches on my '86 740 Turbo Wagon. Any tips on how to replace it? Is it possible to lubricate it? thanks!
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
You may be able to lubricate it but you need to remove it first. Once you have the motor out try a little silicone based oil on the bearing.
To get the motor out, this is courtesy of swedishbricks:
Heater Blower Motor Replacement. [Query:] [Response 1: Kevin Lawler] If you have done several 240's you should be able to do a 740 blower motor with your eyes closed! Remove the under dash hush panel on the passenger side. Next remove the right side kick panel over the fuel ecu, then remove the 2 screws holding the ecu and remove the ecu. next remove the 3 screws holding the ECU bracket, and remove the bracket. Now remove the 5 screws holding the blower motor in place and remove the blower motor. Remove the ground wire from the old motor and unplug the power wire. Install new motor in reverse order. Some cutting and modification may be required depending on the style of the motor. I have done several of these, always in less than 1 Hr. [Response 2: Ney] The only important tip is to remember to disconnect the battery, because the ECU may need to be removed in order to gain access to the blower. Also remember the small black wire with self-tapping screw is ground.
This is a straight lift from the site so doesn't imply you have replaced a 240 unit which is a great deal harder than the 740.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
zaphod
Post by zaphod »
Thanks much, Bill. I'll let you know how it goes -
SkyVolvo
Year and Model: 04 S60 2.5T, 94 850T
Has thanked: 5 times
Post by SkyVolvo »
Hello - I was having the same issue on my '91 740, and followed the directions above to successfully remove the blower motor.
Now that I have the motor out and in my hands, I'm trying to figure out how to get it apart to lubricate the spot where the sound is coming from. Where should I be trying to lubricate it, and how?
In this photo, the center of the fan appears to have an open hole; mine does not. Is that what I should be getting at?
Current Volvo:
2004 S60 2.5T
Volvos Emeritus:
'94 940
'91 740
'94 850T Wagon
zaphod
Post by zaphod »
I tried but was never able to get into mine to lubricate it - I wound up buying a replacement and putting it in, which worked great.
Kirby J
Year and Model: 99 v70, 93 940
Post by Kirby J »
Buy a replacement. These things are installed with the fan bearing at the lowest part of the system. If any moisture/condensation gets into the ventwork, it eventually settles to the bearing on the blower fan. This bearing will eventually fail. A new unit will not solve the problem, but it should be good for 5-10 years. A used replacement will probably fail MUCH sooner. IPD or FCPGroton around $100.
Kirby J
SkyVolvo
Post by SkyVolvo »
Well, when I get back to Denver, I suppose I'll order a replacement. By the way, Kirby, I had to laugh - I grew up in Hendersonville and am back there right now for a visit.
Current Volvo:
2004 S60 2.5T
Volvos Emeritus:
'94 940
'91 740
'94 850T Wagon
SkyVolvo
Post by SkyVolvo »
Finished it up today with a new blower motor. I got an aftermarket from O'Reilly because it was cheap and handy - it fit right in and works like a champ. I'd gotten so used to the screaming-banshee sounds of the old one it was actually a little strange to turn the air on and only hear...air.
Current Volvo:
2004 S60 2.5T
Volvos Emeritus:
'94 940
'91 740
'94 850T Wagon
