OK! That got me to the right section.
It shows up as the fan relay supply with a fusible link right at the starter.
Just be sure that there's still a fusible link there because there's no
other circuit protection in that line. No fuse, no nothing.
If the link gets cut out or replaced with regular wire,
it's a fire waiting to happen.
Glad ya found it!
Need help with starter solenoid wiring
SM1L1NJACK
- Year and Model: 740 1992
I just for giggles took the wire loom cover apart and physically traced the wire. The"brown " pigtail is indeed the Fusible link spliced to the Bat + wire for the Cooling fan
- Been thanked: 466 times
Not true,SM1L1NJACK wrote:I just for giggles took the wire loom cover apart and physically traced the wire. The "brown " pigtail is indeed the Fusible link spliced to the Bat + wire for the Cooling fan
Some clarification for future readers.
1. The "Brown" wire was not Brown, it was RED!
The Aux Fan circuit runs on smaller wire than the big cables (that are attached to the starter solenoid lug).
See below:
2. Below is the photo from my 1998 S70 GLT. I labeled everything for future readers.
- 3178 Views
Last post by Andy for help
- 1618 Views
Last post by jpac
