98 s70 t5 A/C problem
Re: 98 s70 t5 A/C problem
the compressor doesn't kick on unless I manually supply power from the relay
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
I'm confused. Are you jumping the relay or the low pressure switch?johnmc70 wrote:ok, so now everything seems good with the ecc, no lights are flashing. I jumped the low pressure switch and made sure I had enough Freon in it and we are good but the compressor and fan don't kick on and when I jump the relay only the compressor kicks on. Where else should I look to next??
'98 S70 T5
2016 Chevy Cruze Premier
I jumped the low pressure switch and jumped the relay to get the compressor to turn on. I have 35 psi in the system. I reconnect the low pressure switch and put a brand new a/c relay in. all functions work on the ecc no lights flash. With a/c on, the compressor still doesn't turn on
- Has thanked: 1511 times
- Been thanked: 3829 times
Please see the thread here on measuring pressure and report back..
https://www.matthewsvolvosite.com/forums ... 88#p293488
- 1333 Views
- 12 Replies
- 3023 Views
Last post by Jaguar xjs
