V 70 AC -not working
Molibius
Year and Model: V70 1998
Post by Molibius »
This is follow up to my previous posting on this topic.
The facts :
pressure at the charging port reads at 80
AC compressor with the clutch is working
one of the pipe going to fire wall is very cold
the other one (with low pressure switch) is warm.
Any ideas what to do ?
Thanks
Has thanked: 312 times
Been thanked: 818 times
Is that pressure reading when the compressor is running (clutch engaged), or when it is not?
Molibius
Post by Molibius »
When is OFF, means engine off.
What is the normal pressure ?
Thanks
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
at something around 25% of full charge up to full charge the system will have pressure directly related to the temperature of the components of the system. 80 psi would be about 25C.
Effectively static system off pressure is pretty much meaningless.
Molibius
Post by Molibius »
I have no idea about the AC, so what could be the problem?
Why one pipe is cold while the other is warm ?
Molibius
Post by Molibius »
One more,
I suspect that evaporator is leaking.
So how would I know it ?
The one cold one warm pipe would be a typical situation ?
Has thanked: 1611 times
Been thanked: 4072 times
One pipe cold and one warm is correct operation. The only way to confirm a leaking evaporator core is to remove it and inspect (10 hours of labour). At which point, on an old car, you would just replace it. It's about a 100 USD part.i guess it would be possible to evacuate the AV system, disconnect the two Oring connectors at the firewall, and pressure or vacuum test the evaporator in situ.
If you are adding refrigerant to your system, you have a leak. Inspect the whole system and diagnose the evaporator by exclusion. There are no connections behind the firewall, just the evap core.
Molibius
Post by Molibius »
Can I use gauge to measure the pressure so I know if the AC is charged?
I mean if I take the car to a shop, how they will know it?
I am aware of the labour involved with evaporator replacement , by the way did anybody try to sue Volvo for it?
I think all volvo victims (at least from this forum) should do it.
Now the pipes - when the AC produces cold air - both pipes are cold.
When it stops blowing cold air, one of the pipe is warm (the one with sensor)
Could it be because of low pressure/ gas level ?
I'll link to the post by Jimmy on AC measurements.
A shop will evacuate and test with dye ( drive around for a week) or vacuum test or a couple of hours to test for a major leak.
Suing over a part failure on a 16 year old car sounds like a non-starter. Loss of consortium due to no AC might be better route.
Molibius
Post by Molibius »
Oh, I miss my Toyota Camry wagon.
I did almost 600 K (kilometres ) on it.
Did just once AC - put a compressor from junk yard and forget about it.
I have brand new compressor in Volvo and the thing still does not work.
I guess starting a battle over ancient car is not a good idea, I just disbelieve how bad the Volvo is comparing to Camry.
The AC -- I think there is a leak.
Once, they over charged the system so it was freezing up.
Now after normal charge - it works for a day and then is over. Back to starting point
