96 960 blown head gasket
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
grg02001
Year and Model: 960 1996
Post by grg02001 »
cracked radiator at top hose connection lead to over heating. replaced radiator - unfortunately the head gasket went. white smoke pours out exhaust. has anyone ever tried myduraseal? I don't like using sealer but don't want to replace head gasket.. any thoughts? thank you...
jimmy57
Been thanked: 320 times
Post by jimmy57 »
No. Those products have some limited effectiveness on cast iron engines but open deck aluminum is low success rate. The dirty rotten secret of the magic elixir poured into radiators biz is the stopped up heater cores and stopped up oil coolers. In some cases plugged radiators. Your engine does have a coolant to oil oil cooler.
grg02001
Post by grg02001 »
Thanks. No other options?
gmtgmt
Year and Model: Volvo 850 T5R
Post by gmtgmt »
change the headgasket... i find it pretty easy to change. the only anoying part is the intake manifold.
lindy8_man
Year and Model: 1998 S90
Post by lindy8_man »
"fun" project to change your gasket! Do that and check your compression and fluids. Hope and pray you did not warp your heads. I came close to your outcome myself in the middle of nowhere. Replace those radiators Ya'll! it's just a matter of time :)
Beer and DIY Volvo Repairs are proof that God loves us and wants us to be happy.
rgk
Year and Model: Gray 88 245
Post by rgk »
grg probably did warp the heads. Even a slight warp will guarantee destruction of the new gasket. Do yourself a favor and take them to a machine shop where they will inspect the heads for free. Here in Carbondale resurfacing and cleaning costs $55. If there is a chance the heads are cracked, the shop can perform a pressure test, which with the resurfacing and cleaning costs $135.
rgk -- was dickdeadly
