FINALLY, a Vacuum Hose Diagram Topic is solved
Volvo 850 Vacuum Hose Diagram
- Year and Model: Many Volvos
- Been thanked: 76 times
Is the line to the turbo control valve accounted for? The "Blue" line on the turbo control valve winds up on an intake manifold port but I can't remember exactly where it plugged in on mine.
I'll check again but I'm pretty sure it is, thanks Lee.
It's a little more confusing because I have a full SAS delete. I ended up plugging the line coming off the green star check valve (pictured below) and running the yellow star line to above where the green star check valve line ends up near the PCV valve.
Drove it around the block a few times and it seems to be running great with no codes. Before I did this job it was throwing P0172 and P102 within a few seconds of clearing them.
1998 V70 T5
kimothyanne
- Year and Model: 850T 1996 Sedan
Thank you, thank you, thank you. I have been searching for these diagrams for 5 years. I actually ended up replacing all of the inter-cooler hoses as they blew on my first 1994, 850T. Alas, I moved and could not take that one with me so I bought a '97 850T when we settled in our new home. On this one, the turbo gauge never gets past the middle of the black part, but it isn't slow. I am going to check everything out from these diagrams. Thanks again, kimothyanne.
- Has thanked: 311 times
- Been thanked: 817 times
Bobby, please take a picture of the hose and post , or send it to me by pm so we can place which hose you are trying to fix.
- Has thanked: 2856 times
- Been thanked: 1332 times
Please keep the discussion to this thread so others can benefit. Thanks in advance. Bobby, here's how to add a photo to your post.
- 3862 Views
Last post by MarcM
- 4307 Views
- 671 Views
Last post by tryingbe
- 3080 Views
- 2604 Views
Last post by legalstuff
