2006 S40 Power Steering Pump not starting
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
orfeous
Year and Model: 2006
Post by orfeous »
EPS on my car does not want to start!
got a message telling me that the power steering needs service.
This happened a couple of times like a half year ago but dissapeard.. but now its back again..
and it seems its here to stay! haha
VIDA CODES: EPS-0021, EPS-0022, EPS-0071
Just bought a new battery from volvo so that isnt the issue this time.
Someone else got this too? :)
Any solutions or things to try?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
There has been issues with the connections on EPS pump unit. The connectors plug on downward and water can enter and cause corrosion. IN the US there was a recall but I'm not sure how that was handled (if it was handled) in Sweden.
Plug is down below RH headlamp after lamp unit has been removed.
orfeous
Post by orfeous »
Thank you! My service technican on volvo dealer did the check on connectors last time i did my car service.
He said that they was ok..
I can go to my volvo dealer tomorrow and ask about that power steering pump thing.. why was it recalled in us?
orfeous
Post by orfeous »
Went out today to my car and removed headlight... tried to see in the reservoir about the level but i couldnt see any "line" lighted it up with a flashlight also but.. and i tried also to unscrew it.. but it was really stuck :) so i gave up.
Checked also F2 80A fuse in fusebox and it was good, also the fuse in passenger seat. It was shared with ABS system and i have no issues with that.
Tried to locate the connectors and things down near the headlight but.. it was deep down and couldnt reach it.. found a thick red and black wire into a connector on a cylinder :)
so today was a fail :(
orfeous
Post by orfeous »
The pump is not recalled in Sweden :(
i asked volvo dealer.. so it seems that this is gonna be a big cost.. but maybe it isnt that hard to change it myself? have seen some done it..
