85 Volvo 240DL no fire to distributor,fuel injectors or pump
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
lindsey240DL
Year and Model:
Post by lindsey240DL »
I just replaced the motor with another but no fire to the distributor fuel injectors or pump i replaced the ECU but didnt help i hope someone can help Tank you .... Tim !
ToeCutter66
Year and Model:
Post by ToeCutter66 »
Check the fuse under the hood on the drivers side fender. It is near the ignition coil. It is a 25 amp blade fuse. It often gets corroded. Also check your fuel pump relay. These are such common failure points that I keep spare fuses and a relay in my car.
Kevin
