1998 GLT V70 Hard start below 30deg/studders SOLVED
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
1) Just recently the temp has dropped to below 30 degrees at night. Hard to start in the morning. Once it starts, placed in gear and the accelartator pushed the car studders. Once up to temp it runs fine.
Battery seems to have good charge. Help on this one?
2) The check engine light is on. The other night I accelarated and the check engine light started to flash. What might be causing this?
Thanks all
Stephan
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
You need to have the codes read. That will likely tell you what the problem is.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Possibly a bad mass airflow sensor, but read the codes to be sure. An auto parts store will do this for free - write down the code NUMBERS please (we don't care about the description the scanner gives) and bring them back.
'98 S70 T5
2016 Chevy Cruze Premier
stephansvolvo
Allright guys. here are the codes they gave me.
PO172
PO455
Stephan
98 S70 GLT
73 IH Scout ii
stephansvolvo
PO172
PO455
Stephan
98 S70 GLT
73 IH Scout ii
Pauloil
Year and Model:
Post by Pauloil »
that is the temp sensor under the thermostat fixing it is easy. be sure to disconnect battery cable during fix.
you need 19mm open end also
http://www.ipdusa.com/products/5726/114 ... ure-sensor
99 V70XC 158K
95 850glt 188K
stephansvolvo
Thanks. I'll check it out.
Stephan
98 S70 GLT
73 IH Scout ii
stephansvolvo
Pauloil wrote:that is the temp sensor under the thermostat fixing it is easy. be sure to disconnect battery cable during fix.
I replaced the battery yesterday and still wouldnt start this morning. -10 degrees!!!!
I purchased the sensor. Is this hard to put in? Are there any connections through this forum that videos the replacement?
Thanks
Stephan
98 S70 GLT
73 IH Scout ii
rspi
Post by rspi »
stephansvolvo
rspi,
So i replaced the sensor. this thing still wont start! Any other ideas??? I am at a loss.
Thanks Stephan
Stephan
98 S70 GLT
73 IH Scout ii
