terrible gas mileage
I have an 1994 850 turbo that runs great but is getting about 13mpg in the city. I fill the 70litre tank to get 300km or 187miles from the tank. I see that my PCV system is clogged. Can a clogged PCV have that dramatic of an effect on gas mileage or is my problem probably something else. I've done plugs and injector cleaner. No 02 sensor codes or engine lights...
sorry my car has 190 000km on it. I've also followed the instructions at http://www.volvospeed.com/CheckEngine.php to check for any codes, but it doesn't seem to return anything... when I have the jumper in any of the sockets and then press the button for a second nothing happens... anyone know why?
White850Turbo
- Year and Model:
Examine all of your vacuum lines and elbows very carefully. Pay special attention to the one on the passenger side of the intake manifold. It's kinda tough to see, but it's there.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
Volgrrr
- Year and Model: '95 T5 wagon
Apart from poor fuel economy, if your crankcase cannot breath freely, then there is the real risk of the crankcase being pressurised and blowing a real oil seal.
This can be very expensive to repair.
I wouldn't waste any time correcting the situation.
There are only two types of car owners - those who own Volvos and those who wish they did.
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
What is being said here is to get your PCV system serviced....this usually means replacing the oil separator under the intake manifold as well as all of the small vacuum hoses, especially the one that runs to the PCV nipple at the base of your air intake (larger- accordian type) hose. This will help your car breath better and will be good insurance against pressure build up that tends to kill engine seals and cause you to loose money like your pockets have holes in them.Volgrrr wrote:Apart from poor fuel economy, if your crankcase cannot breath freely, then there is the real risk of the crankcase being pressurised and blowing a real oil seal.
ok, i've been examining the car for a whil;e now and I found 2 elbows that have major leakes. Both are the ones that come out of the vacuum tree. 3 go in a 2 come out and its the 2 that come out that are damaged. What do these vacuum hoses do and should I replace this with the stylin motors silicone tubes?
ok. i've ordered the silicone vacuum hoses from stylin motors. Now I want to clean my PCV system as well, but I don't want to order the entire PCV kit from fcpgrotton (since I will use the silicone tubing instead) What other parts will I need to service my entire pcv? Will the silicone vacuum hoses work for the hose that goes from the top of the crankcase to the oil trap? thanks
in the PCV diagram at
http://img141.imageshack.us/my.php?imag ... rboww7.jpg
what is the #7 hose/pipe? can I use the silicone tubing supplied by stylin motors instead of purchasing that part from fcpgroton?
Is everything in this diagram simply vacuum hoses and elbows and clamps except for the oil trap? thanks in advance.
MadeInJapan
#7 is a special pipe with a special connector on the end of it...it connects the oil separator to the heated PCV nipple on the end of the air intake hose (to the turbo or if an NA, to the throttle). It can't be substituted. Actually, most of the PCV kit can't (like the wide but short pieces that butts the oil trap up to the engine, etc.) so I would go ahead and spring for it...your Stylin' hoses will come in handy every where else and you'll use most of it for the other stuff anyway. If you buy the kit from Groton on eBay, you'll get the intake manifold gasket with it and it's actually cheaper than ordering from them directly. Good luck.
- 14 Replies
- 3870 Views
Last post by instarx
- 499 Views
Last post by aaronius
- 14 Replies
- 2372 Views
Last post by sleddriver
- 457 Views
Last post by erikv11
- 389 Views
