Fuel Pump Replacement
William_Cary
Year and Model: 850 1993
Post by William_Cary »
I can't get retaining ring on fuel pump to budge with drift or oil filter plyers. Now what do I try?
1993 Volvo 850 GLT
88,000 miles
No history before 2012, just tuned up.
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
Squirt some PB Blaster into it?
5 others that came and went
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
They sell the wrench/adapter at most auto parts stores. The video below might help.
rspi
Post by rspi »
QuirkySwede
Year and Model: 1998 S70 GLT
Been thanked: 12 times
Post by QuirkySwede »
Do not use a drift or pliers. Go to Autozone with $100 cash and loan:
OEM/Fuel pump replacement kit, Part Number: 27160
http://www.autozone.com/autozone/access ... 05758_0_0_
You'll use the tool on the bottom to hook under and pull up to remove the fuel connections (if you're pulling hard, the tool isn't under the release part), and the part on the right to remove the ring. By paying cash, you'll get your money back as soon as you return the tool (mind the time limit) versus using a card which can take days to be credited back to your account.
And if you don't have a verifiable record of it being done, make sure you replace that timing belt, idler, and tensioner pronto! Whether to replace the water pump at a 70k mile interval or 140k is debated.
Been thanked: 472 times
Post by cn90 »
I used Sears Craftsman Oil Filter Tool:
http://www.sears.com/plews-oil-filter-w ... 6142951201
Crank only enough to "bite" the Plastic Ring. Then twist it CCW to remove it.
I wrote all the tricks below:
DIY: 1998 S70 Fuel Pump RUBBER SEAL
https://www.matthewsvolvosite.com/forums ... hp?t=60329
Below is a photo showing the tool in action:
Post by cn90 »
Post by cn90 »
While there, you may as well take care of:
- EVAP Hose
- Plug the area where the wiring enters the Plastic Top Cover. I used Butyl Rope to plug it:
https://www.matthewsvolvosite.com/forums ... hp?t=60269
https://www.matthewsvolvosite.com/forums ... hp?t=24518
