DIY: 1998 S70 GLT Fuel Vent Hose 9463088 w/o Dropping Gas Tank! Topic is solved
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I have a Fuel Leak, which leaks from the top of the gas tank. I think it is from the Vent Hose.
I benefited from this DIY (Laparoscopic Fuel Hose DIY):
https://www.matthewsvolvosite.com/forums ... =1&t=54739
If you want to drop the gas tank, here it is:
http://volvo850wagon.wordpress.com/tag/hose-2/
So, here is my version. If you do it this way (drilling a small 3/8-inch hole), there is no need to drop the gas tank!
PN 9463088 (#23 in the photo): Hose on top of gas tank ~ $19.
1. See the Fuel Leak.
2. Parts Diagram.
3. Remove all the junks from your trunk. Pry the plastic clips, lift up the carpet, remove the 10-mm nuts. BTW, get a box to store all the odds and ends, as they can fall down the spare-wheel well!
* You can see the area of fuel leak. Note that the hose has 2 different I.D.s (3/8-inch and 5/8-inch).
4. Overlay the new hose, so you have an idea where to drill the 3/8-inch hole.
If you drop the gas tank, this is what it looks like (I borrow this photo from the web):
5. Use small drill bits and work your way up to 3/8-inch bit (wear goggles!). Once the hole is drilled, insert a small screwdriver to undo the clamp.
6. Next don’t yank the hose as you may damage the Plastic Blue Connector. Instead, use Vise-grip to twist (rotate) the hose to undo the “bonding”. Now, remove the hose:
7. New hose is a bit tight, given the tight space you have to work with, so 2 tricks will help with the installation:
a. Enlarge the end with a socket, let it sit for a few minutes so the hose gets used to the enlargement.
b. Once done, add 2-3 drops of fresh oil to ease insertion. Don’t forget the clamps!
8. Note the clamp as viewed through the hole.
9. On the outside, somehow a small vent hose became disconnected (it was a loose fit). I re-inserted it and add 2 zip ties to prevent it from coming loose again:
10. For the final touch, I used some black paint and paint the hole to prevent rust. Let the paint dry, then use a Honda body clip (3/8-inch type, same size as the drill bit) that I had laying around to close the hole:
All in all, it is a 1h job, not to bad as you don’t have to deal with dropping the gas tank, not mention that you have to deal with rusty nuts/bolts holding the straps for the gas tank!
Remember to leave the 2 metal covers (that cover the sending unit and fuel pump) off for now while you fill the gas tank to full to check for leak.
That is it boys and girls!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Interesting write-up. :wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
So the sending unit and pump have different access ports?
beigg
Year and Model: 850 97
Post by beigg »
Yes, different locations that use different ports.
ugh smh 850 Turbo fridge
Goldponcho
Year and Model: '95 yellow T-5R 854
Post by Goldponcho »
Great write-up! This is an issue on my '95, and with the cold weather it'll be nice to tackle this in the garage without dropping the tank. Now to order that hose......
ashlee2319
Year and Model: 2000 V70 NA
Has thanked: 3 times
Been thanked: 2 times
Post by ashlee2319 »
Sorry to jump in, but question. In the picture on "#4", what is inside the top circular smaller panel? Above the fuel pump. I opened mine up the other day and was just curious to what it was.
2000 V70 N/A
1999 V70 GLT - Current project car
ashlee2319
Oh wait sorry, i see... The top of the fuel tank, duh.
Is that cover supposed to come off? I was able to wiggle mine around a little..
2000 V70 N/A
rspi
Post by rspi »
Very nice cn90, keep up the good work.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Wow, amazing skill/imagination on this, CN. Scheduled for inclusion in the VRD.
Also -> Amazon link
Post by cn90 »
I want to consolidate all gas tank leak issues into one place to make it easier for future readers, so there are basically 4 potential places for fuel leak at the gas tank area:
1. EVAP Hose Leak is this very same thread.
2. Gasket at Gas Tank & Filler Pipe:
https://www.matthewsvolvosite.com/forums ... hp?t=60291
3. Fuel Pump Rubber Seal:
https://www.matthewsvolvosite.com/forums ... hp?t=60329
4. Fuel Pump Wiring area:
Hint: if you see fuel in the wiring area (especially after a fill-up), chances are it leaks through the areas where the 2 wires enter the fuel tank via the top plastic cover.
This leak can be so bad (dripping on the ground after a fill-up) that it can fool you into thinking that the cause is any of the 3 items above!
https://www.matthewsvolvosite.com/forums ... hp?t=24518
By far, #4 is the easiest and simplest fix: simply use a small screwdriver to remove old "wax", then apply "Butyl Rope" and press it down to seal. This is what I just did and it is bone-dry now.
So start with the simple thing first!
