1998 V70 AWD No heat
- azeebabee
- Year and Model: '98 V70 AWD LPT
I replaced the heater core and checked the ECC for proper air mixing door movement. I hear a 'gurgling' noise as if water with air in it is passing through the heater core but I only get heat if it sits with the ecc off then open the vents and it's warmish for a few seconds. How do I bleed the air from the system? Could it be a blocked heater hose?
Don't just look at it, drive it.
2006 Mercury Montego Premier. (Wife's wheels)
1998 V70 AWD LPT 249000mls
1971 144 sold with 286000mls
1972 164 sold with 365000mls
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I doubt that. How many miles since you replaced the core? Mine burped with 10 miles of driving. Added coolant the next day and that was it.
When I replaced mine a few days ago, I had good heat within 2 miles.
- azeebabee
replaced core on Friday 12/27/13
- azeebabee
the coolant feed pipes to the heater core get hot but it only blows warm for a few seconds when you turn on the fan then cold air. Warmer by fay than the 7 degrees we have here in wisconsin but not hot.
- Has thanked: 1498 times
- Been thanked: 3810 times
Feel down by your feet on the driver side to see if hot coolant is reaching the core. You can pull away the kick panel and touch the pipes too...they will be hot, so touch quickly!
My guess is your temp blend motor is shot on your car and it's a climate unit problem
- kcodyjr
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 17 times
- Been thanked: 23 times
Both pipes get hot? Then you're getting flow.
How's the coolant pressure? Is the upper radiator hose getting firm?
5 others that came and went
- azeebabee
Yes the hose gets firm. I notice that when I cycle the heater mixing doors that it blows a lot more air when set to cold than when set to hot.
- kcodyjr
A blockage in the air channel? Are you sure you put it back together right?
Was it an OEM or aftermarket core? Some of the aftermarket ones have a coating that needs to be washed off.
- azeebabee
Aftermarket. But I checked with a flashlight in a dark room and didn't see any blockage. I can take it out and clean it as I haven't replaced the plastic panels as I wanted to make sure it worked before I put it completely back together
- kcodyjr
Do a search about it, but I believe you're supposed to wash it in a sink of warm soapy water.
- 319 Views
Last post by Flyingdutchman
- 449 Views
Last post by TheLoneAviator
