1998 V70 AWD No heat
azeebabee
Year and Model: '98 V70 AWD LPT
Post by azeebabee »
I replaced the heater core and checked the ECC for proper air mixing door movement. I hear a 'gurgling' noise as if water with air in it is passing through the heater core but I only get heat if it sits with the ecc off then open the vents and it's warmish for a few seconds. How do I bleed the air from the system? Could it be a blocked heater hose?
Don't just look at it, drive it.
2006 Mercury Montego Premier. (Wife's wheels)
1998 V70 AWD LPT 249000mls
1971 144 sold with 286000mls
1972 164 sold with 365000mls
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I doubt that. How many miles since you replaced the core? Mine burped with 10 miles of driving. Added coolant the next day and that was it.
When I replaced mine a few days ago, I had good heat within 2 miles.
azeebabee
Post by azeebabee »
replaced core on Friday 12/27/13
azeebabee
Post by azeebabee »
the coolant feed pipes to the heater core get hot but it only blows warm for a few seconds when you turn on the fan then cold air. Warmer by fay than the 7 degrees we have here in wisconsin but not hot.
Has thanked: 1504 times
Been thanked: 3817 times
Feel down by your feet on the driver side to see if hot coolant is reaching the core. You can pull away the kick panel and touch the pipes too...they will be hot, so touch quickly!
My guess is your temp blend motor is shot on your car and it's a climate unit problem
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
Both pipes get hot? Then you're getting flow.
How's the coolant pressure? Is the upper radiator hose getting firm?
5 others that came and went
azeebabee
Post by azeebabee »
Yes the hose gets firm. I notice that when I cycle the heater mixing doors that it blows a lot more air when set to cold than when set to hot.
kcodyjr
Post by kcodyjr »
A blockage in the air channel? Are you sure you put it back together right?
Was it an OEM or aftermarket core? Some of the aftermarket ones have a coating that needs to be washed off.
azeebabee
Post by azeebabee »
Aftermarket. But I checked with a flashlight in a dark room and didn't see any blockage. I can take it out and clean it as I haven't replaced the plastic panels as I wanted to make sure it worked before I put it completely back together
kcodyjr
Post by kcodyjr »
Do a search about it, but I believe you're supposed to wash it in a sink of warm soapy water.
