Getting these codes after the warning message "reduced engine performance" message. The rpm's drop well below 1000. If I turn off & restart the engine it runs fine for an intermittent period of time.
I have noticed at least one vacuum line running under the intake manifold has an approx. 2" split along it's length.
I am preparing to replace all vacuum hoses and any other hose needed.
I would appreciate any ideas you all could offer.
Thank you.
Peter
05 S80 P0442,P0496,P0497,P2407 + "Reduced Engine Performanc"
matt5112
- Year and Model: 1999 S65
- Been thanked: 3 times
Have you tried looking up what the codes mean in relation to late model Volvo?
For example, the P0442 is a small evap leak and it's typically the J hose on the canister in the back that is at fault. Eg: http://volvoforums.com/forum/volvo-s80- ... s80-61788/
