No more than 8lbs of boost..
Jush
Year and Model: 1997 855 GLT
Post by Jush »
I am having a problem with low boost I can not seem to fix, I am getting at most 9lbs. I have a 97 GLT but I happened to come across a 95 turbo ECU so I plopped that in hoping it would spruce up my boost pressure, and to no avail (although the car is faster, still low boost pressure). I have tried everything from tightening the wastegate to eliminating the TCV altogether. I can not find the source of my low boost pressure. ANY advice will be helpful. (my current wastegate is off of a newer xcv70 since mine had been spun at some point and was no longer operating properly)
Thanks
Josh
c70_lindsay
Year and Model: 99 S70 T5.
Post by c70_lindsay »
I'm not quite sure about the 850 specifics, how much boost is an 95 turbo supposed to run? It may only be 8lbs of boost.
Jush
Post by Jush »
I've heard people get upwards of 10, around 15 and I would be happy, I just don't know what is preventing it from increasing pressure with all the things I've done.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
A GLT is a low-pressure turbo, so 8 is correct. If everything is Stage 0, I'd run a manual boost controller, but be warned: it's not if you'll blow your engine but when. Your 850's engine was not made for much more than 8 pounds boost. Yes, there is some margin, but with a nearly 18-year-old engine, anything can happen.
Also -> Amazon link
1998v70xcbill
Year and Model: 1998v70xc
Been thanked: 3 times
Post by 1998v70xcbill »
Matthew1 is right on wiht +8 psig. Go 10% higher at most "at your own risk". Mine pull to high rpms no problem and it's a v70xc.
Bill
