I am having a problem with low boost I can not seem to fix, I am getting at most 9lbs. I have a 97 GLT but I happened to come across a 95 turbo ECU so I plopped that in hoping it would spruce up my boost pressure, and to no avail (although the car is faster, still low boost pressure). I have tried everything from tightening the wastegate to eliminating the TCV altogether. I can not find the source of my low boost pressure. ANY advice will be helpful. (my current wastegate is off of a newer xcv70 since mine had been spun at some point and was no longer operating properly)
Thanks
Josh
No more than 8lbs of boost..
c70_lindsay
- Year and Model: 99 S70 T5.
I'm not quite sure about the 850 specifics, how much boost is an 95 turbo supposed to run? It may only be 8lbs of boost.
- Has thanked: 2856 times
- Been thanked: 1332 times
A GLT is a low-pressure turbo, so 8 is correct. If everything is Stage 0, I'd run a manual boost controller, but be warned: it's not if you'll blow your engine but when. Your 850's engine was not made for much more than 8 pounds boost. Yes, there is some margin, but with a nearly 18-year-old engine, anything can happen.
1998v70xcbill
- Year and Model: 1998v70xc
- Been thanked: 3 times
Matthew1 is right on wiht +8 psig. Go 10% higher at most "at your own risk". Mine pull to high rpms no problem and it's a v70xc.
Bill
Bill
- 30 Replies
- 6148 Views
- 1873 Views
Last post by vtl
- 18 Replies
- 4962 Views
Last post by GoldCO
- 1764 Views
Last post by dahammer
- 896 Views
Last post by RickHaleParker
