1998 S70 Trivia: Can you identify this small tube?
Rondo
- Year and Model: 2000 S70 GLT/SE
Re: 1998 S70 Trivia: Can you identify this small tube?
Knew my response was dumb, but I've learned to seek out simple answers first. Glad someone could help.
Nautic Blue '00 S70 GLT/SE, RIP @ 273625 Miles
Black '00 S70 GLT/SE, 141K Miles
BrianD
- Year and Model: 1998 S70 (base)
No it wasn't a bad idea -- the hose had to come from somewhere that wasn't obvious! But this Michigan winter is giving me lots of chances to test out the windshield-fluid-delivery-system, so I was sure that wasn't it.
Thanks,
Brian
Thanks,
Brian
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 116 times
The tube will slip off the elbow often, especially when you tinker in the area.BrianD wrote:Ding ding ding! Great team work, thanks.
It is the same line diagnosed in the post linked to above by xHeart, and suggested by others:
https://www.matthewsvolvosite.com/forums ... 0&p=245663
I should have been more thorough in searching past threads.
Both ends connect to the air filter box. One along the firewall-side, near the top, and the other on the front bottom corner, on the passenger (right) side. I gather this second connection is the "vacuum tree." In that spot I found a busted elbow connector, but the connector at the other end is just missing.
I think I have enough info to get the parts and fix it, but if anyone has any pointers or other thoughts, they'd be more than welcome!
The engine will run at a higher rpm, bit noisy.
I applied a thin coat of gorilla at each end for adhesion.
- Has thanked: 1511 times
- Been thanked: 3827 times
I've never stolen a coat from a gorilla...sounds dangerous, Shirley
- misha
- Has thanked: 152 times
- Been thanked: 402 times
If both ends connects to air filter housing...that's the one.It goes from the front bottom of the air filter housing to the upper back of it.BrianD wrote:...Both ends connect to the air filter box.
If it's not that line....than...it looks like a pcv system vacuum line which goes from alternator & power steering area(the nipple from left side of the intake manifold )to a flame trap housing nipple.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
BrianD
The fix is done! As predicted, it's idling 100~150 rpm lower. And perhaps I'm just excited to have it fixed, but I think I'm getting better throttle response too. Thanks all for your help!
Especially for those who might be using this thread for reference in the future:
I've attached a picture of the lower connection (referred to as the vacuum tree). I found it difficult to see but wanted a clearer view because it didn't feel like a "tree," and was able to get my cell phone down there for a photo. The other connection (up top) is shown by Greg Dawson in this thread: https://www.matthewsvolvosite.com/forums ... 0&p=245663
As for the parts, I was missing an elbow at each end and decided to replace the line anyway, since it's old enough to have a driver's license itself. I was not able to find the exact parts, but put together a nice solid connection with parts from a local specialty Volvo shop. All the fittings were really snug, so I opted to let the gorilla keep it's coat.
- WhereTheTubeGoes.jpg (146.96 KiB) Viewed 347 times
- 9 Replies
- 3088 Views
Last post by jimmy57
- 9 Replies
- 2059 Views
Last post by Sommerfeldt
