thanks for your help in advance
1983 240DL Water pump not matching, what to do?
I think the prior owner did an engine swap because I went to put in a new water pump and it doesn't match. So how can I find out what type water pump fits this car?
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
rgk
- Year and Model: Gray 88 245
First find out which engine you have. The serial number is stamped on the left (driver's) side of the cylinder block toward the front, usually around where the distributor is located. This may also have the model number.
If not, you can input the serial number at this website to find out which model you have: http://equipmentwatch.com/QuickSearch.d ... urer=volvo
rgk -- was dickdeadly
