Went to O'reilly auto parts and got the following brake pads BrakeBest® Brakes Select™ Ceramic - Brake Pads Part # C1003.
Ran into a very interesting issue on the outside pad. There is a little nub made of the ceramic material on the outside of the pad so that when you install it in the caliper it does not fit flush. I used a wonder bar to break it off pads, but was wondering if anyone else ran into this issue.
Also, another big things is to make sure you have a can of PB Blaster around to loosen those bolts. I think my hands still hurt!
2004 XC90 Brake pad replacement
tailor
- Year and Model: 2004 XC90 2.5T AWD
- Been thanked: 2 times
I think that you may have the incorrect brake pads, meant for the larger rotors and the newer models of the Xc 90. I came across the same problem, when I did my front brakes, but never confirmed this to be the case. I also removed the nub, thought it was metal and not ceramic.
I have noticed there is a slight "pull " to one side upon applying the brakes, which may or may not be part of the "pull" problem.
Due to the delightful subzero temps here in Canada at the moment, I have not opened things up to have another look for the problem.
Let us know if you experience the same problem.( I replaced the rotors as well).
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Abe Gottschalk
tailor
Upon father research the "pull" seems to be related to bushings….going too have to look there as well.
Abe Gottschalk
Abe Gottschalk
It has been a week since removing the nub and I haven't noticed any issues with pulling or brakes not working properly.
I will keep that the nub issue in mind if I have to replace the pads anytime in the near future.
Other than the transmission issue which I am not sure will ever be fixed the car is just ok for us.
