2004 XC90 Brake pad replacement
shortkidd
Year and Model: XC90 2004 T6AWD
Post by shortkidd »
Went to O'reilly auto parts and got the following brake pads BrakeBest® Brakes Select™ Ceramic - Brake Pads Part # C1003.
Ran into a very interesting issue on the outside pad. There is a little nub made of the ceramic material on the outside of the pad so that when you install it in the caliper it does not fit flush. I used a wonder bar to break it off pads, but was wondering if anyone else ran into this issue.
Also, another big things is to make sure you have a can of PB Blaster around to loosen those bolts. I think my hands still hurt!
tailor
Year and Model: 2004 XC90 2.5T AWD
Been thanked: 2 times
Post by tailor »
I think that you may have the incorrect brake pads, meant for the larger rotors and the newer models of the Xc 90. I came across the same problem, when I did my front brakes, but never confirmed this to be the case. I also removed the nub, thought it was metal and not ceramic.
I have noticed there is a slight "pull " to one side upon applying the brakes, which may or may not be part of the "pull" problem.
Due to the delightful subzero temps here in Canada at the moment, I have not opened things up to have another look for the problem.
Let us know if you experience the same problem.( I replaced the rotors as well).
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
tailor
Post by tailor »
Upon father research the "pull" seems to be related to bushings….going too have to look there as well.
Abe Gottschalk
shortkidd
Post by shortkidd »
It has been a week since removing the nub and I haven't noticed any issues with pulling or brakes not working properly.
I will keep that the nub issue in mind if I have to replace the pads anytime in the near future.
Other than the transmission issue which I am not sure will ever be fixed the car is just ok for us.
