2001 V70 power window. Problem with switch
sourimaha
Year and Model: V70XC 2001
Post by sourimaha »
MKS; I have 2001 V70 XC; Problems with the Master Window Switch. All other 3 windows and the passenger side mirror can be controlled perfectly with the Master Switch.
Only the Driver's window and the Driver's side mirror cannot be controlled by the master switch.
I have replaced with an used master switch belonging to the same year V70XC.Again all other windows and the passenger side mirror work perfectly but not the deriver' s side window or the mirror.
What can be done? does this need programming by the dealer or are there any other solution>
I will appreciate any help. hanks
BobLane
Year and Model: v70 1999
Post by BobLane »
I have cleared the "master control" by inserting key into the door and turning 5 times- give it a try
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
After 2000, the window systems in these cars,
( as well as the cars themselves ) changed entirely.
The previous two posts really don't belong in this
section of the forum. Let's not confuse people. Mods?
Has thanked: 1500 times
Been thanked: 3812 times
Duly split topic, thanks.
We will catch it faster if you use the alert button ! In triangle, next to the warp core eject button
