mine is a 1997, but i have personally driven other volvos in the the pre-2000 years that also suffer from this issue. When the car is warmed up, going from -D- to -N- then to reverse, it kicks quite roughly. mine in particular does it regardless of how slowly your shifting, and the rpms are steady.
so to the real question, when is it a point of concern for the life of the tranny? can this be just a quirk of the older volvo trannies, or is it in fact a sign of old fluid (in my case fluid is very clean) or a tranny on its way out?
Volvo 850 tranny kick going into reverse
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
I had a pretty good thump when the transmission buckle mount was bad.
It's always done it to some extent though, especially when changing quickly (like to parallel park). A quick stop in "N" will lessen the impact.
'98 S70 T5
2016 Chevy Cruze Premier
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
_
Mine was from the front engine mount which is the one located on the passenger side of the engine below the timing belt area. The mount did not fully collapse like the first one but it did start to rattle the inside of the car and shifted hard when moving the Lever. The transmission itself had no problems.
_
_
sacricide
- Year and Model: 1997 Volvo 850R
even STOPPING in -N- even for few seconds has no effect.
but ill have to check these mounts, if i end up doing the REAR MAIN SEAL, ill need to make sure i have a good tranny in place or else its going to be one hell of a waste of time.
- 251 Views
Last post by billjohnson121
- 608 Views
Last post by MoVolvos
