2001 C70 T-5 me7 engine and subframe mounts
VolvoC70T5
Year and Model: Volvo C70 T5 2001
Post by VolvoC70T5 »
Hi,
Can anyone direct with the following "problem" as i am not sure what exactly i need to order for my C70 T5 with 480.000 km's done on the clock regarding engine and subframe mountings....which alll needs to be replaced ( no more rubber on subframe mountings and bad/worn engine ones )
A lot of cranking/knacking over bumps - all links, cv joints, wishbone were allready changed with new, and rechecked and that is all in new conditions. Also engine mounts with No 29 and 34 allready changed with new.
I have took a look myself on the volvowebparts store from where it is not clear what exactly do i need.
On the scheme bellow i made few "picks" if these are the parts i need ( by numbers on the picture)
59
12
14
4
9
2x 41
4x (33,34,35) ( 4 - it is not clear for me, do i need 4 pieces each for each square subframe fitting or what is it like)
If anyone can give me correct instruction for part no would appriciate it a lot, i dont want to buy and throw money away with buying wrong items....
Cheers
VolvoC70T5
Anyone? ;(
Has thanked: 1613 times
Been thanked: 4075 times
Call the gals and Guys at IPD or Europarts....they are the experts!! Don't forget to use your discount code
