Replace heater core trick
volvomadness
Year and Model: v70 2003
Been thanked: 9 times
Post by volvomadness »
Have replaced a good number of heater cores v70, s70, 850's
One trick I learned to avoid all that nasty coolant in the car without clamping off lines is to vacuum out the reservoir completely. I use a wet vac, tape a smaller extension to the hose, stick it in the reservoir and suck out all the coolant. Only a tiny amount of coolant remains when I remove the heater core.
Has thanked: 292 times
Been thanked: 765 times
Great tip. Compressed air works great too (keep the psi down!), you can blow it into a bag then you don't have to clean out the shop vac.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Deleted
volvomadness
every good shop should have a wet-vac. Its was just a tip!
instarx
Year and Model: XC70 T6 2011
Post by instarx »
My shop vac is a turkey baster. :)
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Would you have to get the coolant level below the inlet pipes on the firewall?
Has thanked: 1505 times
Been thanked: 3818 times
I had blown so much coolant into the carpets another gallon didn't matter...
Been thanked: 472 times
Post by cn90 »
If one decides to replace the coolant as part of the heater core job, then there is an easy way to deal with this:
1. Drain the coolant (d/c the lower rad hose ---> radiator).
Unless your radiator is new, you don't want to open the petcock, which can break!
2. Loosely re-attach the lower rad hose.
3. Add water to the reservoir.
4. Run the engine for 2-3 min just to circulate the fluid through the system.
Repeat this cycle a few times with water refill between cycles.
After a few cycles, the system should be 95% water and 5% coolant.
So when you replace the heater core, try to catch any spilled fluid so the carpet is not wet. Even with a spill, some water will soon evaporate anyway.
Once you are done, remember the system is mostly water, so calculate appropriate amount of pure coolant to add. Do not use premixed 50-50 type in this situation.
rspi
Post by rspi »
My experience is, when you drain the radiator you get about 1 gallon of coolant out. So if you have washed the system out with water, you can drain the rad, measure it, and add back full strength coolant, about a gallon. When washing the system out with water, you should do it with a few gallons of distilled water, not tap water.
