Have replaced a good number of heater cores v70, s70, 850's
One trick I learned to avoid all that nasty coolant in the car without clamping off lines is to vacuum out the reservoir completely. I use a wet vac, tape a smaller extension to the hose, stick it in the reservoir and suck out all the coolant. Only a tiny amount of coolant remains when I remove the heater core.
Replace heater core trick
volvomadness
- Year and Model: v70 2003
- Been thanked: 9 times
- Has thanked: 292 times
- Been thanked: 765 times
Great tip. Compressed air works great too (keep the psi down!), you can blow it into a bag then you don't have to clean out the shop vac.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Deleted
volvomadness
every good shop should have a wet-vac. Its was just a tip!
- instarx
- Year and Model: XC70 T6 2011
- Has thanked: 1 time
My shop vac is a turkey baster.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
- Has thanked: 1505 times
- Been thanked: 3817 times
I had blown so much coolant into the carpets another gallon didn't matter...
- Been thanked: 471 times
If one decides to replace the coolant as part of the heater core job, then there is an easy way to deal with this:
1. Drain the coolant (d/c the lower rad hose ---> radiator).
Unless your radiator is new, you don't want to open the petcock, which can break!
2. Loosely re-attach the lower rad hose.
3. Add water to the reservoir.
4. Run the engine for 2-3 min just to circulate the fluid through the system.
Repeat this cycle a few times with water refill between cycles.
After a few cycles, the system should be 95% water and 5% coolant.
So when you replace the heater core, try to catch any spilled fluid so the carpet is not wet. Even with a spill, some water will soon evaporate anyway.
Once you are done, remember the system is mostly water, so calculate appropriate amount of pure coolant to add. Do not use premixed 50-50 type in this situation.
- rspi
Contact rspi..
My experience is, when you drain the radiator you get about 1 gallon of coolant out. So if you have washed the system out with water, you can drain the rad, measure it, and add back full strength coolant, about a gallon. When washing the system out with water, you should do it with a few gallons of distilled water, not tap water.
