1996 850 (base model) PCV system
Has thanked: 292 times
Been thanked: 765 times
Re: 1996 850 (base model) PCV system
In the great DIY that I linked up there, step number 10 is key. Make sure that oil drain port is wide open, if it isn't then scrub it out well with a brush and some carb cleaner (and then change the oil!).
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
It is easy to test if the PCV is clogged. Age and mileage play a great factor in a system like that. 18 year old hoses and tubes are just old old old.
Are you running 91+ octane? The NA cars have pretty high compression motors and if you are running low octane fuel, the car can retard timing to avoid predetonation (knock).
Also, a car motor can be destroyed in 25.000 miles. If someone goes that long without changing oil or runs the car 4 quarts low for several thousand miles, it can wear it out. I would do a compression test to see the true health of the motor. If compression is low, that will effect your power output.
So, I it were me, I would:
1. Check compression.
2. Pump 91+ octane.
3. Replace the PCV system.
Hope things pan out good.
boxycar
Year and Model: 1996 850
Post by boxycar »
rspi wrote:It is easy to test if the PCV is clogged. Age and mileage play a great factor in a system like that. 18 year old hoses and tubes are just old old old.
2. Pump 91+ octane.
Noted RSPI, thank you and I always put 91+ octane, compression test looks easy enough. can't wait to try it.
Stay tuned, buying the parts today
boxycar
Post by boxycar »
So I am back! I changed the PCV system and did a tranny drain and fill (so 3.5quart exchange)
the car shifts a little better and has some more power now, there is no more oil shooting out of the oil cap ( I can tell by now seeing fresh oil ontop of the spark plug cover) there is also barely any white smoke coming out of the oil dipstick tube.
I tried the glove test for the PCV (taking the oil cap off and putting a glove over the hole to see if it fills with air) and it still fills with air though so I fear its not 100% better. I did not use the heater hose as was advised because my car is non-turbo but now I sort of regret not doing it.
So next step from here is a compression test, drive 100miles and do another tranny drain and fill and maybe redo the PCV with the heater hose.
thanks for the advice, I will let you know what happens.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
You mean oil dipstick, not cap, right?
Hmmm...that may not have been a wise move. Why did you decide not to?
boxycar
Post by boxycar »
No I did it over the oil cap, that what this video suggested
I decided to not do it because my car is not turbo. that was the thought process anyways
polskamafia mjl
Turbo or not an older engine will still have more blow by which is what the larger diameter hose will help with.
