So this is really a strange problem, I noticed it the other day when I was merging onto the freeway.
Here's what happens, I put the pedal to the floor, and I'll get up to about 90km/h, and for a brief moment, a sort of pause where there's no acceleration, then continues to pause at incriments of about 20km between from 90 upward. I really have no idea what the problem could be. I am running about 16 psi of boost and have removed the TCV. The computer in the car currently is a 4.4
This doesn't happen only on full throttle, as soon as there is an aggresive amount of pedal it starts doing this.
I will try and get a video up.
thanks
-Josh
97 850 Intermittent pauses at full throttle
- Has thanked: 2660 times
- Been thanked: 1248 times
Sounds like fuel cutoff.
Dang, I guess Volvo doesn't want you to have too much fun.
Thanks, I guess I saw that coming, I'll set the boost pressure a little lower and try to find a happy medium.
The reason I wasn't sure if it was cut off was because I was told cutoff was much more aggressive i.e. "like hitting a wall".
Thanks and sorry for thread clutter.
It's not exactly like hitting a wall, but it is abrupt cessation of power, until I back off the throttle.
