1998 S70 T5 Serpentine pulleys
mar601
- Year and Model: 1998
- Has thanked: 34 times
- Been thanked: 5 times
Getting some noise from the serpentine belt when engine is cold but goes away after warm up -- sort of a grinding noise. I'll assume it's one of the pulleys? I see an idler pulley and tensioner pulley And it seems to be coming from the idler pulley anyway. Thought I'd order both -- should fix it right? Looks like I don't have to replace the entire tensioner?
- Been thanked: 468 times
Correct. I'd keep the tensioner.
I'd replace the serpentine belt if it has more than 110K miles.
The tricks to replace the pulleys are below:
https://www.matthewsvolvosite.com/forums ... hp?t=53722
