1996 858 GLT NO START
ANTS
Year and Model: 850 GLT 1996
Post by ANTS »
HI .
I just acquired this car volvo 850 glt and have not driven it on the road - problem is that it does not start but only starts up only when fuel is poured down the intake and it runs only until the added fuel is burned up -
also runs with or with out the MAF sensor plugged in or not . Can any one advise me a way forward .
jose456891
Year and Model: 850 GLT 2.4 1996
Post by jose456891 »
Check for fuel pressure, if none:
Check the fuel pump relay (103), the overload relays (J), fuel filter
If fuel pressure present:
Check the injector relay on the radiator shroud
Your problem is on the fuel delivery, if the motor runs it means that all the engine management and ignition modules are working. I would strictly focus on electrical and common expendibles (fuel filter).
Been thanked: 472 times
Post by cn90 »
I posted info on fuel pump relay trouble-shooting in forum using jumper wire to jump 15 and 87.
Search for the post.
