Disconnected battery, ground first. Cleaned battery terminals and cable clamps. Disconnected battery cable at CEM and cleaned terminals. Disconnected connectors under drivers seat and sprayed with contact cleaner (hey, I heard it worked for someone elseha_smith wrote:I will work on checking grounds and voltages during the week and report back. It is original alternator, starter, O2 sensors. No CEL, no codes that a parts store reader will pick up, only the goofy message and warning triangle. If I was in it for the long run I would get the Vadis.precopster wrote:My money's on the CEM. Try contacting XeModex in Canada for a rebuild quote.
Before this check earth and voltage supplies to all modules. Is the alternator producing too much AC voltage? ( yes I DO MEAN AC not DC) Measure this voltage with engine running.
Allen
Next step will be to check voltages!
Allen
