1998 s70 glt Timing belt not tracking true
old cigarette
Year and Model: 1996 850 turbo
Post by old cigarette »
I pulled the timing belt cover and found the belt tracking forward into the cam cover.The belt has made a 1/8 th inch grove in the cover. I replaced the water pump / tensioner pulley / idler pulley / hydraulic tensioner / and belt. The belt is from Gates. The Tensioner is Beck/Arnley. Both pulleys are INA. The belt still tracks forward by the same amount. The only thing I can think of that would cause this is a bad tensioner pulley or idler pulley. I've used INA pulleys in my 96 850 without problems. Any suggestions as to what else would cause this ?
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
There are INA tensioner rollers and then there are counterfeit INA tensioner rollers. The latter will cause the belt to track off of the cam sprockets exactly as you describe. I'm to the point where the only way I trust that I am getting the actual, non counterfeit, part is to buy it straight from a Volvo dealer and take it out of the blue box myself. Even a well known vendor has sold me the counterfeit as an OEM brand part and they have known about it for years. One other problem to look out for with some of the counterfeits is that the shoulder on the mounting bolt doesn't hold the casting off of the face of the block and casting binds and won't pivot once it is torqued down.
Although it is a horrible PITA I have removed the roller and the bearing from the original casting and then replaced it with the roller and bearing off of the "new" tensioner roller casting and used the old casting. Miraculously everything tracks correctly then.
old cigarette
Thanks Lee. Because of the PITA factor I think I'll go blue box on both the pulleys. I don't have any faith in INA after this even though they are OE manufactures. I hope the blue box parts solves the problem, expensive lesson Thanks again.
gdog
Year and Model: '96 855T, 98 S70 GLT
Has thanked: 2 times
Been thanked: 5 times
Post by gdog »
Ozark Lee wrote:... Even a well known vendor has sold me the counterfeit as an OEM brand part and they have known about it for years. One other problem to look out for with some of the counterfeits is that the shoulder on the mounting bolt doesn't hold the casting off of the face of the block and casting binds and won't pivot once it is torqued down.
+1 to what Lee said; exact same thing happened to me on first 850 TB change, and I fixed it the same way too.
1996 855T, 190K miles, N/A cams, N/A intake manifold & TB, do88 drop-in intercooler w/RIP, R ExMan, OBX_improved, green injectors, dw200, 18T w/7cm angle flange, 540i MAF housing, M4.4 VS DIY tune, wmi, Bilstein TCs, IPD sways, AEM boost and AFR gauges. Fun DD!
1998 S70 GLT, 140K miles, Bilstein TCs, IPD sways, do88 drop-in intercooler w/RIP. Want to do more mods but she says leave her car the f*** alone!?
Been thanked: 466 times
Post by cn90 »
The problem is the "Gates" TB. Search forum, someone had the same issues using Gates.
This is why I always use Conti parts.
Believe it or not, the TB kit from the dealer is even cheaper than Conti parts, go figure!
