Timing belt not tracking straight?
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I just did the timing belt on my 850 today. I used the Aisan kit, which includes a Gates belt, and INA tensioner and idler pulleys. I got it together, and while watching it run without the cover, I noticed the belt wanders back and forth. I first noticed it on the idler, but upon close inspection I think it's moving a bit on all of them.... back and forth. Maybe a 1/16" at the most, probably less. The belt never protrudes off the edge, just moves right up to it.
Is this normal? Now, I wish I would have watched the old one run. I'm new to timing belts.
I did notice that the new idler is lighter duty than what I believe to be the original that I removed. I almost re-installed the original, but I did detect just a but of play in the bearing. The idler was pretty much identical to what I removed, but the original was made in Germany, and the new one, in Slovakia.
I probably could have only changed the belt.... now I really want to get the bluetooth device, so I can check my mileage.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I had a similar experience with a Gates belt. I eventually replaced it with a Conti belt and that got rid of the wobble.
viewtopic.php?t=73552
Has thanked: 1609 times
Been thanked: 4065 times
If you have metallic pearl paint you shouldn’t use Gates parts…..they die and go to Heaven
454cid
Post by 454cid »
erikv11 wrote: 22 Jan 2022, 10:14 I had a similar experience with a Gates belt. I eventually replaced it with a Conti belt and that got rid of the wobble.
Your video is exactly what mine is doing. I think I'll leave it at least until it's warm out, and plan to check it every so often until then.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
