Bad compression
I did a compression test today and got 120-120-120-120-90, is there a simple fix to this or is it time to sell? I did a wet test in cylinders 1 and 5 and got 150 & 120, so it was bad even wet. I'm not going to lie, I'm pretty upset. But at least I didn't start putting anything into it and now I know how to do a compression test (thanks rspi). Your thoughts and condolences would be appreciated, lol.
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
I just did the same thing yesterday and had virtually the same readings on my '95.
It is a bummer. I like the car but probably not enough to spend the $ on a rebuild.
Sigh.
Sigh.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- Been thanked: 4071 times
Is it running well with decent fuel mileage ? Before you totally panic the fact that they are all close is good. That's more diagnostic than the actual readings.
There is always a possibility your instrument is bad and you real compression is higher and your engine is in good shape. Was your battery fully charged and did you have all plugs out and throttle plate open ?
On edit..I missed that 90 on the end. Ugh.
- Year and Model: Many Volvos
- Been thanked: 76 times
Sometimes you can improve things with a Seafoam treatment. It is fairly cheap to try it and watching the giant smoke cloud after the top end treatment freak out my neighbors is kinda fun anyway.
I am similarly situated with my '94 except my 90 PSI cylinder is number 1 and I've tried all of the miracle in a can products to no substantial improvement. I really like that car even though it has around 280k on it and at some point I will probably drop a new engine in it.
I bought the compression tester today at harbor freight, all the plugs were open at the same time, what do you mean by the throttle being open? I'm not sure the condition of the battery but its starting good and the mpg is pretty decent, around 24 in town
- alschnertz
Hmmm. I did forget to hold the throttle wide open. I wonder how much difference that'd make.
My readings were 115, 125, 125, 125,125. All bumped up about 25 psi with oil in the cylinders.
Generally, the car runs pretty well. Does burn some oil though - about a quart every 700 highway miles or so. I had thought it was valve seals, but now figure it's a combination of rings and valve seals. Gets around 22 mpg in town on 10% ethanol fuel. Yea, it's a tired engine. It's too bad because the body is excellent and just about everything works.
For now, I'll keep running it. I figure a rebuild would probably run around $3,000 - $4,000 or so and I just can't swing that right now. Is that accurate?
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- Has thanked: 311 times
- Been thanked: 817 times
That's great for city miles, keep driving it!alschnertz wrote:... Gets around 22 mpg in town on 10% ethanol fuel. ...
