I've searched and come up empty. Is there a step-by-step guide for throttle body removal in order to replace the TPS?
Thanks!
Dave
'95 850 Turbo - TPS Replacement Guide?
- Year and Model: Many Volvos
- Been thanked: 75 times
It is a pretty easy task. You will need to have a new throttle body gasket on hand but remove the throttle linkage from the throttle body. It is a ball and socket junction and you just pull it away from the ball to release it. From there unplug the TPS connector and remove the throttle body. The TPS is held on with two small screws. Remove the screws and replace the sensor. The sensor is keyed so it is hard to mess it up.
Clean up the old gasket from both the throttle body and the intake manifold and use your new gasket when re-installing it.
- Been thanked: 471 times
1+,
The following guide should help you:
http://volvospeed.com/volvo_repairs_how ... n_egr.html
Once done, make sure you adjust the throttle cable properly.
There should be a very slight slack on the cable.
- Has thanked: 292 times
- Been thanked: 765 times
Maybe you want to take this opportunity to clean the throttle body up real well (often a needed service item), but keep in mind you can just remove the TPS with the throttle body on the car. The whole job will take maybe 20 minutes.
Remove those 2 bolts (like 7 mm head), remove TPS, replace.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- 8283 Views
Last post by IronMike
- 11337 Views
Last post by gpdeering17
