Please post a few photos of your "exposed" wires so we can help.
If not already done, check/replace spark plugs, most people here use Bosch copper ($2.20/each at local parts store). Info in forum.
1994 850 Base Stalls in Wet Weather
Barcelo_850
- Year and Model: 850 N/A, 1994
- Been thanked: 471 times
This is what it should look like. You may want to remove the black wire (probably someone tried to install a tachometer), then use heat-shrinkable tubing to seal the blue wire.
Another option is junk yard ignition coil, which goes for about $10 at Pick and Pull places...
I forgot to mention that as a test, get a spray bottle.
Run the engine, then spray a very gentle mist at the blue wire, if the engine stumbles, then you just made the diagnosis. Just don't touch any high-tension wire when the engine is running. These HT wires carry some 48,000 Volts!!!
Barcelo_850
It has an aftermarket remote start installed by the PO, but hasn't worked since I've owned it.
Ben850
- Been thanked: 7 times
I would probably get rid of any of the non functioning parts and try to start from the OEM standpoint.Barcelo_850 wrote:It has an aftermarket remote start installed by the PO, but hasn't worked since I've owned it.
Electronics are fickle on these cars. I have come to find that myself.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- 629 Views
Last post by sane
- 21 Replies
- 3068 Views
Last post by eriscentro
