changed oil, now have lifter ticking all the time
Been thanked: 471 times
Re: changed oil, now have lifter ticking all the time
Post by cn90 »
Has anyone tried ATF or Lucas or Seafoam as in the thread below?
http://volvoforums.com/forum/volvo-850- ... try-71337/
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
- edit -
lies and misinformation were spread here; i will be tarred and feathered in the square on sunday evening, if you're thirsty for vengeance.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
j-dawg wrote:if you switch to a heavier-weight oil, i'd expect more ticking.
No :!:
If you have valve ticking with low weight oil the ticking will go away with heavier weight oil.
Also if the engine burn some oil between changes,heavier weight oil will improve things.The engine will reduce,if not completelly stop,to burn oil.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
+1 Misha
j-dawg
Post by j-dawg »
- edit -
ah, we're talking about ticking that doesn't go away, not just at startup. my mistake.
incidentally, am i right about the lighter oils for startup ticks? ie, if i were ticking with a 10W, might i not tick with a 5W?
Has thanked: 292 times
Been thanked: 765 times
Many people remedy the ticking by going to heavier weights, I think you're saying it backwards? So, if it ticks with 10w, the ticking will be worse with 5w.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
