Hello Volvo enthusiasts
My OBD II is showing two codes P0420 and P0430. I know these two codes are related to catalytic converter efficiency but wondering/hoping something else is the cause besides the cat. In addition to the codes mentioned, code P0234 (overboost, pressure too high) appears. I cleared all codes after checking for obvious vacuum leaks (for example, loose and cracked hoses etc ). The two codes P0420 and P0430 consistently re-appear after a few miles. I also feel hesitation when abruptly accelerating (turbo) at any speed and I hear a high pitch air intake/sucking sound. After the hesitation, the car accelerates and hesitates a little more. Could the poor performance and converter codes be related to the turbo trouble code, P0234. I’m attaching a picture of the “Rich to lean threshold voltage” and a word document containing the freeze frame data that was recorded at the time the codes happened. Thanks in advanced for any help provided.
2003 S80 T6 Trouble codes P0420 and P0430
Freeze Frame trouble code.docx- (10.58 KiB) Downloaded 170 times
Update:
The MAF sounds as if it is having a asthma attack when I press down on the accelerator petal. When I removed the MAF so it could be cleaned, a section of the housing was not intact (one side was lifted exposing the electronics it was housing). Is there a specific code that would appear if the MAF isn't functioning property.
- 820 Views
Last post by davidisurf
- 4503 Views
Last post by chitownV
