'99 V70 Base, auto non-turbo -- Seat Recovering and SRS code
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
I will be recovering a front passenger seat. I probably do not have a chunk of time to do the job in one fell swoop. Can I remove the seat (with the neg. battery terminal disconnected, of course), then reconnect the battery and drive around for a few days with the passenger seat our without setting an SRS code?
Anybody ever done it? Drive around without a passenger seat without setting an SRS code?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 1503 times
Been thanked: 3817 times
When I did my evap AC I remember reading advice that if you power up the SRS without components connected on a 1999
1 You will get an SRS code
2 Only a dealer can clear these.
FWIW
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
With the seat out connect a 2,2 Ohm resistor across the two wires that go to the green/ purple two pin plug that normally connects to the seat, do this with the battery disconnected, when you fire the car back up the resistor will fool the cars SRS system in to thinking the airbag initiator is still connected - You should be able to get the resistor from Radio Shack/ Tandy for no more than about 25C etc - Mike
E Showell
Post by E Showell »
Thanks for the suggestion, Mike. I'm more inclined to just finish the work in one sitting.
'95 855 auto (sold)
mikealder
Post by mikealder »
My 2000 phase one V70 still has resistors fitted some eighteen months after I swapped the seats for earlier ones with the mechanically fired SIPS bags, works a treat - Mike
