1998 S70 T5 ABS relay location?
hammertime
Year and Model: '04 XC90, '07 XC70
Post by hammertime »
After an extensive search of this site for existing posts on my problem I now need to ask: Where is the ABS relay located? I have the following code; ABS-443 (pump motor electrical or Mechanical fault) Many posts on the subject refer to a ABS relay, I either can't find it or have a misunderstanding of what it is. I own 3 similar cars so I often swap suspected problem parts between them to help diagnose problems. If the problem transfers to the other car I have found the culprit. I have swapped the ABS control module between 2 cars with out change, so have eliminated that from the possibilities. I next want to try swapping the relay to either confirm or eliminate it as my problem.
'04 XC90
'07 XC70
Zamboni Model 545 (my work vehicle)
Prev. '68 142, '96 850 GLT Sportswagon, '98 V70 AWD, '98 S70 T5, '00 V70 XC
first car ever owned: '74 BMW 2002tii
Been thanked: 504 times
Post by cn90 »
hammertime
Thanks CN90 I had read through that thread before. In it is mentioned a relay and the control module. I have experience with the control module and don't believe that to be the problem, but I don't know what is being referred to when it mentions replacing the relay.
'04 XC90
'07 XC70
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
There is no relay, the motor control is a solid state circuit built into the module. The 443 code is one of the telltale codes of broken solder joints on the circuit board.
hammertime
jimmy57 wrote: The 443 code is one of the telltale codes of broken solder joints on the circuit board.
So since I have eliminated that possibility by switching the module with another car with no change to either car, I am beginning to think that I need a new pump.
'04 XC90
'07 XC70
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
Ohm out the pump or apply 12 volts to it. It's a lot easier than replacing it.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
esl_97_850_T5
Year and Model: 1998 S70 GLT
Has thanked: 18 times
Been thanked: 27 times
Post by esl_97_850_T5 »
On my 1997 850 T5, removal of fuse 9 generates ABS-443 (if removed by itself, without removing any of the other two ABS fuses).
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
