1994 Volvo 850 radiator install going down hill
clearfmc1981
- Year and Model: 1994
A wire broke while I was installing a radiator. the wire plugs into another wire that is resting in front of the ac condenser the wire goes behind the passenger headlight. I tried to splice it but it's just not enough wire, and to old and brittle. Anyone know what it's for and called so I can order a new one. any help would be greatly appreciated. thank you
clearfmc1981
Close it's for the headlight. (Wallflowers one headlight song playing in background). I can't get enough wire to do a splice, I tried looking on ebay for the harness, but am having a hard time finding it.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
add a piece of copper wire and solder it inline (series)
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
clearfmc1981
Sorry I stand corrected. you were right it was the wiper wire. I have no idea why the headlight stopped working for that brief moment. I took the assembly apart tested the wires, and they all worked I put the headlight back together and it worked. So far I changed the thermostat and thermostat sensor, the oil trap, and flametrap as well as pvc hoses, I also replaced the rad. but I am finding a ton of wires and sensors that are not hooked up. I have no idea where they go, would it be alright to post a few pics under my topic.
- Has thanked: 1503 times
- Been thanked: 3817 times
Please post some pictures. For finding wiring connections find the origin of each mystery wire and describe the number of connectors on the end too. Trying to help with poorly described wiring is a bit frustrating so take time to make it easy for the help! Use a photo edit program and label each one in your pictures to avoid ambiguity.
clearfmc1981
I hope you guys don't mind sorry for the late reply I just took some pictures of things that are some concern. thank you so much and any comment help feedback would be awesome. now she ain't pretty but she runs, sort of (as soon as I jump it she fires up once I shut her off no matter how long she ran she's dead. I'll upload the pics and explain the best I can sorry new to this and it's my first time uploading anything thank you.
clearfmc1981
Ben850
- Been thanked: 7 times
Your '94 may have the VVIS manifold which adds a few more vacuum lines and a vacuum solenoid as well as check valve.
I saw something at your air box that looked like a clothes drier tube.
Could you get another shot of that area? I am intimately connected to the '93 to '94.4 VVIS intake.
https://www.matthewsvolvosite.com/forums ... IS#p263166
It is a thread that I had posted for an N/A modification for that year variable velocity manifold.
You may have that if it is an early '94.
Also, what is the radiator issue? Is it a fan/electrical issue, or plumbing.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
clearfmc1981
Yep I'll post some more pics tonight. I gotta put back the dip stick tube in and do an oil change. for the life of me I still can't figure out why it won't hold a charge. thank you again for all your support. yeah she's a dream car doesn't look pretty but I swear to God she'll run no matter what.
- 910 Views
Last post by savkaklopot
- 2155 Views
Last post by Livens
