I have a 2000 V70 wagon (base model) and lately I remember noticing that if I left the left turn signal stalk down (it seems to not turn off automatically anymore for a left turn but will still for a right), then even with the engine off and key out of the ignition. the left turn signal light will be lit (and not flashing). I thought that the right turn signal was flashing OK and the problem was only with the left but this week (no money and I've been busy
I noticed only after the turn signal issue started, but might be related, that my hazard switch stopped turning the hazards on and off -- the switch is underneath the radio on the dash in this model.
it's hard to tell on a bright day outside but I think that all of the turn signal lights (side marker, front and back on both the left and right sides) are actually lit, but they are not blinking.
to summarize, I am having 3 possibly related issues:
1) turn signal lights are solid if you turn them on with no flash
2) turn signal light is still lit with key out of the ignition if the stalk on the steering column is in the turn signal on position
3) the hazard lights don't turn on and off at the switch
the fourth issue (the turn signal not returning to neutral after a turn from a left turn) is not as big an issue unless it's causing the other issues!
is this a bad relay/flasher somewhere, maybe or is the turn signal switch gone bad? this is the base model v70, year 2000.
thanks for any suggestions!
I don't have too much money for repairs but my daughter drives the car so I'll fix it, I promise!
best regards,
Piesia
