So I recently noticed a coolant loss, sweet smell in my car and damp carpets that were sticky, aka a heater core leak. I still had to get home so I was running the fan to keep air flowing and when the heat turned on (car starting to overheat) it shot out moisture/smell so I quickly turned off heat and let the car sit at my house.
Today I got to fix it and when I start the car up the system smokes and steams again (car was really warm) and there is smoke and a burning electrical smell and the fan gives out.
Popped open the ACC as I am fixing my car it appear to have shorted (posting pictures).
Is it shot? Repairable? Anything else that may have gone?
I a simply bypassing the heater core in the engine compartment for now, heater core is drained. Will replace later, but I would like the climate control (AC, Fan) to function now.
1993 Volvo 850 Heater Core Leak, ACC Failure?
- Has thanked: 1503 times
- Been thanked: 3817 times
Board level repairs are a tough place to start in electronics. I would ebay or pick and pull a used unit and replace the whole thing. It might help fixing the old one with a good one side by side.
Repairing burnt traces on a board is tough..maybe 25% success rate IMHO.
Ben850
- Been thanked: 7 times
It is the capacitors that have burnt up. The first three of those four in the picture are the ones that burn.
There is a thread where someone has replaced them with success, but the '95 to '97 ECC does not use the capacitors and is more of a solid state unit.
That is what I had switched to my '93.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Ben850
Yes. I have a '96 in mine.alexk243 wrote:Would a 95-97 ACC controller work in my 93?
I don't think the leak is what caused your ECC unit to fail. They just do. The ones of that configuration seem to all fail sooner or later.
Search some threads, there are a few, for ECC failure or the like. There is more information that I have already forgotten than I still know.
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
Glad you got your system working with a replacement unit!
Just wanted to share a photo of the internals of the ECC unit from my '97 855. It definitely doesn't have the row of smaller electrolytic capacitors that burned up in your '93 ECC unit. In place of the capacitors there is now a row of diodes (D111, D106, D112, D107, D115, ...). The board looks to have been redesigned. I went through this board last year and replaced all the old Nichicon electrolytic capacitors with new high temperature, low ESR Panasonic caps.
- 12 Replies
- 1968 Views
Last post by humbertoflores63
- 11 Replies
- 8706 Views
