2004 S60 Weird A/C Problems
My a/c blows nice and cold on the driver's side, while on the passenger side, I would say it's cool at the most. Could it just need a new charge? Second problem, possibly unrelated. Sometimes when a/c is on, the center driver's vent will blow out a white vapor or smoke. It's really weird and doesn't have much smell or anything to it. I have no clue would that could be. Any ideas?
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Vapor's not a problem, just condensation like breathing out in the cold air. The passenger side issue is probably a jammed up vent control thing under the dash and most likely an easy fix. Sorry I don't really know how to check if the vents move the way they should.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 78 times
When my 2003 V70 was blowing cold on one side and warm on the other side, the problem was that the refrigerant charge was low. You should find the low pressure side fill port sort of hidden under the P/S reservoir and coolant bottle.
- Has thanked: 1505 times
- Been thanked: 3817 times
It's much more likely that this is a blend door problem than a charge problem. The cold air on the driver side means the evaporator core is getting nice and cold and this means the charge is pretty close to correct.
Make sure the climate system drain is open, the vapour could be water stuck in the climate system which will help corrode things if left.
Corrected by jimmy below...later model AC different than my 1999 with regard to full flow evaporator prior to blend doors. It's good that are people like jimmy here.
jimmy57
- Been thanked: 320 times
The individual side to side temp control systems have a wall in the ductwork from the evaporator through the heat blend doors to the distribution housing. When they are low on refrigerant side to side temp difference can be a result. I can't remember which side gets hot though.
A first easy try is to turn that side temp knob FULL hot and wait a couple of minutes and then turn it to FULL cold and see if it gets cold. This is a way to force a blend door calibration correction.
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
I just had a similar issue; the RH side temp control potentiometer in the CCM was 'noisy' thus causing the temp damper motor to fluctuate within a few notches back and forth. Tried calibration to no avail and then fixed it in less than 30 min. by replacing the whole board in the CCM with one from a salvage module that I'd got earlier for parts. (No soldering or reprogramming required).
If you go this way, do not forget to disconnect the battery.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
