2001 s80 front shocks have 1/4 in gap at top
lilblkshp
Year and Model: 2001 s80
Post by lilblkshp »
replaced shocks, pads, mounts/bearings and still have this 1/4 in gap at top. is this normal?
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
It is.
Post a photo to verify assumption.
lilblkshp
Post by lilblkshp »
Thanks a lot. Will post pic when I get back to the shop
SimLyons
Year and Model: 2001 V70 T5
Post by SimLyons »
Just replaced everything in my front suspension. There are no gaps between the upper bearing and fender well where the 3 nuts go. The strut mounting nuts also need to be tight and flush against that special upper bearing rubber/metal flat "washer". Make sure of your torque settings.
Sim
matt5112
Year and Model: 1999 S65
Been thanked: 3 times
Post by matt5112 »
I think the OP is referring to the gap between the strut mount and the top washer that is bolted to the strut shaft.
xHeart
Post by xHeart »
SimLyons wrote:Just replaced everything in my front suspension. There are no gaps between the upper bearing and fender well where the 3 nuts go. The strut mounting nuts also need to be tight and flush against that special upper bearing rubber/metal flat "washer". Make sure of your torque settings.
Matt makes a point.
Would you post a photo SimLyons.
A flipped star nut would add to the spacing - a correctly installed example below.
correctly installed...
SimLyons
Post by SimLyons »
My photo would be no different from the above. Does anyone have an "exploded view" of the sequence of all the correct pieces on the S-80? (Or XC-90)? That would help us all I think.
Sim
